Use this guide to restore the power loss caused by a misplaced sensor on a Simagic Alpha Mini Direct Drive Wheelbase.
Frequent usage can misalign the positional sensor, reducing its power output, which is further exacerbated by the rotating motors during operation. As a result, the inertia and dampening of the wheelbase can be affected, leading to less than desired hardware performance.
Before beginning, be sure that your Simagic firmware is up to date and FFB (Forced Feedback) settings are correctly calibrated.
Alongside following these instructions, you should refer to this device's user manual to make installation and use quick and convenient while adhering to its safe operation guidelines.
Disconnect all cables from the wheelbase.
Use a 2.5 mm Hex Key to remove the two 10 mm screws that connect the wheelbase to the mounting plate.
Lay the wheelbase right side up, ensuring the "Simagic" logo is on top.
Rotate the wheelbase 180 degrees so the bolts on the back of the device are facing you.
Use a 2.5mm M3 Hex Key to remove four 4 mm screws.
Use a 1.5mm M1 Hex Key two remove two 5 mm screws from the back magnet.
Turn the wheel shaft until the Wi-Fi symbol is facing up.
Turn the magnet clockwise until one of the screw holes is facing up and the other screw hole is facing right to realign the positional sensor (magnet).
Use a 1.5 mm M1 Hex Key to tighten two 5 mm screws and secure the sensor into position.
