Sigrow Soil Pro + Assembly
  1. Sigrow Soil Pro + Assembly, Gather materials: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Gather materials: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Gather materials: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • PCB RR02 or higher 'coated
    • Sigrow Soil Sensor
    • (Top left to bottom right) Case Body +, hat +, solar, bottom inner plate +, fan holder.
    • Sunon Fan 5VDC
    • Solar panel 110x80
    • Tools (top-left to bottom right) : tin, soldering station, flat head screw driver, cable peeler, pliers glue gun (optional).
    • Cable double insulaton: +6 wires, 20 cm
  2. Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cable length is aprox 20-22 cm
    • Peel both ends, keep the non-peeled part short
    • Group them, twist and solder them together
    • On the opposite side you will only keep two colours: black and yellow
  3. Sigrow Soil Pro + Assembly, Solder cable solar panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Solder cable solar panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Solder cable solar panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder
    • Remove the plastic sheet
    • Slide solar panel in parasol
  4. Sigrow Soil Pro + Assembly, Fan mount: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert fan in fan holder
    • Pay attention to the fan air flow direction, it should be upwards
  5. Sigrow Soil Pro + Assembly, Peripherals: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Peripherals: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From top to bottom:
    • Solar Panel mounted and with cable soldered (side with Sigrow letters)
    • Fan (cable enters from bottom)
    • Soil Sensor (cable enters from Sigrow 3 circles logo side)
  6. Sigrow Soil Pro + Assembly, Attach fan holder to main case+: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Attach fan holder to main case+: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fan holder should be inserted in main body case by pressure
    • If there's not a tight fit there are 2 options:
    • Option 1: Request a new fan holder
    • Option 2: Use the hot glue gun.
    • tight fit could be interpreted as: "if with very hard shaken the fan holder and main case will not disconnect and stay solidly attached.'
  7. Sigrow Soil Pro + Assembly, Bottom inner plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Bottom inner plate: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rectangular gap (for temperature humidity sensor) goes slightly in the left.
    • Bottom right tiny circular hole is for the fan cables
  8. Sigrow Soil Pro + Assembly, Confirm orientation: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Confirm orientation: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sigrow 3 circles side-> Soil Sensor
    • Letter side -> Solar panel
  9. Sigrow Soil Pro + Assembly, Soil Sensor connection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Soil Sensor connection: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Soil Sensor connection: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert cables into connector, check in 3rd image in this step that the ports are open
    • Use pliers to cut white cable
  10. Sigrow Soil Pro + Assembly, Solder fan cables: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Solder fan cables: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Black ground
    • Red positive
    • Cut with pliers cable excess from behind
  11. Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cables enter from the back of the PCB
    • Yellow is positive
    • Black is negative (closer to the edge)
    • Cut with pliers cable and tin excess
    • Soldering station is very hot, dont touch it with your hands
  12. Sigrow Soil Pro + Assembly, Insert PCB in case - Cable details: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Insert PCB in case - Cable details: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It's great to leave some extra cables in good shape
    • ~10 cm for the soil sensor bended as inverted-U
    • Twist the fan cable (it's very long) and bend as inverted-U
    • if PCB doesn't slide down with a gentle push or slides out too easy when case is upside down new case should be requested.
  13. Sigrow Soil Pro + Assembly, Closing the case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sigrow Soil Pro + Assembly, Closing the case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After sliding PCB in, connect the solar parasol and the hat +
    • If the fit is not great inform Sigrow senior technician
  14. Sigrow Soil Pro + Assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congrats, you have completed a Soil Pro+
    • Please request from your Senior technician the latest packaging guidelines
In case of doubt contact manufacturing@sigrow.com
Sigrow
crwdns2935283:005/14/20crwdne2935283:0
1,075 crwdns2915208:0crwdne2915208:0
Sigrow crwdns2935289:0Sigrowcrwdne2935289:0
Community
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 247
