Siemes Surpresso Compact coffee outlet Replacement
  1. Siemes Surpresso Compact coffee outlet Replacement, Coffee outlet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemes Surpresso Compact coffee outlet Replacement, Coffee outlet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemes Surpresso Compact coffee outlet Replacement, Coffee outlet: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To the left and right of the coffee outlet you will find two slots on the underside of the front cover.
    • Insert a spudger in the front edge of this slot and loosen the clips that fasten the front cover.
    • Pull the front cover forwards and off.
    What happens when the problem is the opposite? The extraction time has become little, less than 15 seconds, the grinder is set to coarse, the coffee is from the same bag, and obviously, the color and taste is lighter. I did clean the brewing unit. Unfortunately, there is no help in the troubleshooting part of the manual.
    Hausbrandt addict - crwdns2934203:0crwdne2934203:0
    Is the grinder really set to coarse? Try to set it as fine as possible! If that doesn't help, you'll have to open the device. Examine the grinder: is it clean? My guess: you should replace the grindstones. Another possibility: replace the seals in the drainage valve.
    VauWeh -
    Hi, thank you for the prompt reply. I have always used the coarse set, as the manual suggests, for stronger coffee. I will check on the grindstones and get back.
  2. Siemes Surpresso Compact coffee outlet Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemes Surpresso Compact coffee outlet Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemes Surpresso Compact coffee outlet Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The image shows the machine after the front cover has been taken off. The four slots where the clips were are easily recognizable.
    • The movable coffee outlet is surrounded by a casing. Place an opening tool in the gap that separates the two halves of the casing.
    • Slide the tool along the gap, until the front casing becomes loose.
    • Remove the front casing.
  3. Siemes Surpresso Compact coffee outlet Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemes Surpresso Compact coffee outlet Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the supply tube with a spudger from the connection. Pay attention to the outer wire spiral.
    • Remove the two Torx T15 screws.
    • Remove the black coffee spout.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
259 214 crwdns2915208:0crwdne2915208:0
crwdns2935297:0294crwdne2935297:0
The replacement coffee outlet for the Surpresso S50 TK6500x costs €50 (as of 2024). To clean it, soak in hot water for 10 minutes, then use compressed air to dry it
ftonny - crwdns2934203:0crwdne2934203:0
Yes, this part ist (nearly) sold out and not produced anymore. So the only way is to try to clean it, which is difficult. Maybe you can use a syringe with a silicone tube attached. Prepare a strong cleaning solution.
VauWeh -
crwdns2942667:0crwdne2942667:0 5,133
