Siemens-Maquet Servo-i Battery Module Replacement
    • Check the battery date. The battery needs replacing after 3 years.
    • The manufacturing date is listed in the format (year-week) on the battery label.
    • Servo-i User Manual page 19.
    • If battery status on touchpad display is red make sure to replace battery modules.
    • At least one battery module must be installed at all times. If not the ventilator will not work properly.
    • Store uninstalled batteries at 15-20 degrees celsius.
  1. Siemens-Maquet Servo-i Battery Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wait for the battery to be fully charged.
    • To check this, press the battery power symbol button on the battery.
    • All four LED's must be lit.
    • Servo-i User Manual page 20.
  2. Siemens-Maquet Servo-i Battery Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With gas, patient tubes and test lung connected, let the Servo-i run in a ventilation mode.
    • Disconnect mains power to the unit to allow battery operation.
    • Allow ventilator to run and make sure 'No battery capacity'- alarm is not activated.
    • Servo-i Service Manual 5-2.
  3. Siemens-Maquet Servo-i Battery Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The time between the 'Limited battery capacity'- alarm and the 'No battery capacity' alarm must not exceed 7 minutes.
    • The event log contains the records of alarm times.
  4. Siemens-Maquet Servo-i Battery Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens-Maquet Servo-i Battery Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens-Maquet Servo-i Battery Module Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • See if the upper part of the module is equipped with a latch. This means it is fixed and follow these instructions to disassemble a battery from the battery module.
    • 1. Locate a small hexagonal wrench or screwdriver.
    • Place the tool in the small hole on the right hand side.
    • 2. Simultaneously push the release button.
    • 3. Remove the tool, while still pressing the release button.
    • 4. Continue to keep the button pressed until the battery pops out.
    • 5. Pull out the battery module.
    • Servo-i Service Manual 4-18.
Monroe Erle
crwdns2935283:005/04/20crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G2, Zimmerman Spring 2020 crwdns2935289:0Cal Poly, Team S1-G2, Zimmerman Spring 2020crwdne2935289:0
CPSU-ZIMMERMAN-S20S1G2
crwdns2942667:0crwdne2942667:0 1,298
