Siemens-Maquet Servo-i Bacteria Filter Replacement
  1. Siemens-Maquet Servo-i Bacteria Filter Replacement, Filter for Gas Modules: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Bacteria Filter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Bacteria Filter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Bacteria Filter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
  5. Siemens-Maquet Servo-i Bacteria Filter Replacement, Bacteria Filter for O2 Cell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist off white filter cap.
    • Service Manual 7 - 4
    • Use the Maintenance kit, 5,000 hours to replace the bacteria filter for the O2 cell.
rachel davis
crwdns2935283:004/19/18crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G2, Zimmerman Spring 2020 crwdns2935289:0Cal Poly, Team S1-G2, Zimmerman Spring 2020crwdne2935289:0
CPSU-ZIMMERMAN-S20S1G2
crwdns2942667:0crwdne2942667:0 598
