Siemens Surpresso - Open Bosch Benvenuto
  1. Siemens Surpresso - Open Bosch Benvenuto, brewing unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto, brewing unit: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto, brewing unit: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Never forget: Pull the power plug!
    • Remove all attachments such as water reservoir, coffee compartment lid, trester drawer.
    • Remove all coffee beans from the bean hopper.
    • Open the side flap.
  2. Siemens Surpresso - Open Bosch Benvenuto: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the three rubber caps on the brew group.
    • Using a strong flat-blade screwdriver, adjust the three plastic slots underneath so that the "unlocked" position is indicated.
    • Note: with the newer version of the brew group, only one lever needs to be flipped.
    • Pull out the brew group. If it is stuck, pull firmly and evenly, but with feeling, preferably at the bottom right.
  3. Siemens Surpresso - Open Bosch Benvenuto, remove back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto, remove back panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven Torx T10 screws on the rear panel.
    • Do not remove the back panel completely yet, the power switch is still connected.
    • Lift the back panel away.
    • Remove the two flat plugs from the inside of the power switch.
  4. Siemens Surpresso - Open Bosch Benvenuto, top cover removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto, top cover removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto, top cover removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top cover is engaged with bayonets in several places. It must first be pushed back about 1 cm and then lifted away upwards.
    • Grasp the powder compartment cover firmly and pull it upwards out of its hinges. Otherwise it will be in the way of the top cover.
    • Pull the top cover back about 1 cm. If it sticks in front, you can help a little with plastic levers.
    • Lift the top cover away from the top.
  5. Siemens Surpresso - Open Bosch Benvenuto, left side panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens Surpresso - Open Bosch Benvenuto, left side panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The side panel is attached to the front edge with three bayonets. It must therefore be lifted out upward.
    • Grasp the side panel firmly at the rear edge and pull it backward and upward at the same time. It should come off quite easily.
    • When reassembling, make sure that the bayonets on the front edge engage properly.
  6. Siemens Surpresso - Open Bosch Benvenuto, right side panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Follow the steps in reverse order to reassemble your device
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
288,745 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2942667:0crwdne2942667:0 587
