Siemens Surpresso gear drive replacement
  1. Siemens Surpresso  gear drive replacement, opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Siemens Surpresso  gear drive replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Torx T10 screws on the top.
  3. Siemens Surpresso  gear drive replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens Surpresso  gear drive replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Siemens Surpresso  gear drive replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens Surpresso  gear drive replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Siemens Surpresso  gear drive replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens Surpresso  gear drive replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Siemens Surpresso  gear drive replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
  7. Siemens Surpresso  gear drive replacement, Gear Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens Surpresso  gear drive replacement, Gear Drive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens Surpresso  gear drive replacement, Gear Drive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate clockwise the expansion box about 60 degrees and pull it out.
    • The expansion box is frequently filled with coffee oils or grounds. Clean it from time to time. It can easily be separated into two halves.
  8. Siemens Surpresso  gear drive replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The drainage valve is directly plugged to the gear drive. The drive is fixed with five Torx T10 screws on the center panel behind the brew group.
    • Remove the five Torx T10 screws holding the gear drive in place.
  9. Siemens Surpresso  gear drive replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens Surpresso  gear drive replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the gear drive outwards to the left. Pay attention, several cables might get caught.
    • Lay the gear drive on its side. Loosen the upper water connector by pulling the clamp and than sliding off the hose. Mind the O-ring on the end of the hose, replace it if necessary.
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
289,185 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
My replacement valve (original Bosch part) didn’t fit correctly - after it was mounted, the light plastic part couldn’t be moved forth and back without getting stuck from time to time, so the machine wouldn’t be able to brew any coffee afterwards. I fixed it by reusing the light plastic part from the old valve. The machine works perfect now!
Soren - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 122
crwdns2942667:0crwdne2942667:0 5,841
