Siemens EQ6 Service Menu
  1. Siemens EQ6 Service Menu, Siemens EQ6 Service Menu: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Service Menu, Siemens EQ6 Service Menu: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Siemens EQ6 Service Menu, Siemens EQ6 Service Menu: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the machine on normally.
    • Touch the "Menu" field, it is slightly darker. The settings menu for language, water hardness, etc. appears. But that's not the service menu yet.
    • Touch the first (espresso) and last (hot water) fields in the selection at the same time. The fields are dark.
    • Wait until the selection fields are brightly lit. The service menu appears.
  2. Siemens EQ6 Service Menu: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Siemens EQ6 Service Menu: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can take the selection one step further by touching the V-shaped area.
    • Start the respective menu item by touching the start/stop area
    • Plenty of items to select from and those are largely self-explanatory (in English).
    • The component test and the sensor test are of particular importance,
    • Other useful items are the error memory and the log files.
    • Press the power button to exit the service menu.
Reverse the steps to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
281.104 crwdns2915208:0crwdne2915208:0
crwdns2935297:0301crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:030crwdne2931471:0
crwdns2935297:01.543crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Ask for service manual did not get an answer to a simple question
Frank - crwdns2934203:0crwdne2934203:0
@frank54967 Try this link for the service manual.
VauWeh -
Hallo in die Runde, bei meiner Maschine kann ich das Menue nicht öffnen. Die Tasten sind komplett gesperrt, die Anzeige schreibt zwar 3 sek Menuetaste drücken,aber es passiert nichts. Auch das Drücken der beiden Kaffeetassen Symbole bringt keinen Erfolg. Gibt es einen Trick die Maschine komplett zu redeten?
Tom - crwdns2934203:0crwdne2934203:0
Maschine einschalten....Taste "Menü" drücken...dann werden die Felder oben dunkel. Dann die Tasse rechts mit dem +Zeichen drauf gleichzeitig die 1. Tasse links "Espresso" zusammen drücken bis sich das Servicemenue öffnet. Vorsicht beim Setzen auf "Werkseinstellungen" der Bezügezähler geht auf "00000"
Maschine ist EQ6 s300
Helga - crwdns2934203:0crwdne2934203:0
Hallo ich habe dieses Komponentenmenü durchgeschaut und bei dem Temperaturtest 78 Grad angezeigt. Ist das normal oder sollte die höher sein?
Carmen Buchholz-Hammer - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 25
crwdns2936753:07crwdne2936753:0 261
crwdns2936753:030crwdne2936753:0 918
crwdns2942667:0crwdne2942667:0 17,525
