Sidekick II Outer Casing Replacement
  1. Sidekick II Outer Casing Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Outer Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sidekick II Outer Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Outer Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Outer Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Outer Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
michael albaum
crwdns2935283:001/20/10crwdne2935283:0
87 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-19, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 3-19, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S3G19
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,560
