Shure SM58 XLR Connector Replacement
  1. Shure SM58 XLR Connector Replacement, Connector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shure SM58 XLR Connector Replacement, Connector: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shure SM58 XLR Connector Replacement, Connector: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
    • Make sure you are not holding the microphone connector by the wires.
    • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
  2. Shure SM58 XLR Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shure SM58 XLR Connector Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the microphone connector in one hand and the microphone base in the other.
    • Line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  3. Shure SM58 XLR Connector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shure SM58 XLR Connector Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  4. Shure SM58 XLR Connector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
    Hi looks simple but I can't undo screw turns so far and locks up. Can you help. Kind regards.
    Tony White - crwdns2934203:0crwdne2934203:0
    Are you trying to disassemble or reassemble the microphone?
    Daniel Berger - crwdns2934203:0crwdne2934203:0
    In my case, i try to disassemble.. But it wont come off. Anticlockwise the screw… infinite turns… TheThe connector is not stuck, it wabbe a bit, but the screw maybe wont recess enough.
    nunoandrade - crwdns2934203:0crwdne2934203:0
    How do I replace the screw? Lost it, and need to replace it.
    Katrina - crwdns2934203:0crwdne2934203:0
Following these steps should reinstall the XLR connector back into the microphone.
nat coll
crwdns2935283:009/27/12crwdne2935283:0
745 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-53, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 7-53, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S7G53
crwdns2935297:032crwdne2935297:0
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 18,273
