For this repair, you will learn how to replace a motherboard. An important aspect would be knowing how to use the soldering iron.
Remove the suction pad by pulling the suction out of the slot that it is in.
Remove the four 9.09mm Philips #1 screws that hold the 2 pieces of the cover together.
Pull apart the two halves.
Hold the base and pull up on the battery.
Remove the four 5mm Phillips #1 screws from the motherboard.
Desolder the two wires connecting the battery tp the motherboard.
Desolder the four remaining wires that are connected to the motherboard.
