Shower Handle O-ring Replacement
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    Reverse position of pliers pictured
    ajbdo1959 - crwdns2934203:0crwdne2934203:0
  3. Shower Handle O-ring  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your groove joint pliers, loosen and remove the cartridge stem.
  4. Shower Handle O-ring  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shower Handle O-ring  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
Cori Fitzpatrick
crwdns2935283:003/20/16crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-6, Lauer Spring 2016 crwdns2935289:0Michigan Tech, Team 1-6, Lauer Spring 2016crwdne2935289:0
MTU-LAUER-S16S1G6
I have to change my shower handle, but the plumber asking me to change the shower valve also. But I can’t see any reason to replace the shower valve, is it really necessary to change it when changing shower handle.
Thanks.
Rose Geiger - crwdns2934203:0crwdne2934203:0
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - crwdns2934203:0crwdne2934203:0
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 23,977
