Shower Handle O-ring Replacement
crwdns2869540:0crwdne2869540:0: 2.8万
21
99
416
27,870
crwdns2955950:0crwdne2955950:0: 8
crwdns2960004:04crwdne2960004:0, crwdns2960008:04crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 7
crwdns2959982:07crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
If you have a shower head with a constant drip, follow this simple and easy guide to replace the rubber o-ring in your shower handle. Replacing the O-ring can help prevent hard water build up, rusting, and wasting water.
    1. Shower Handle O-ring  Replacement, Shower Handle O-ring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure your water main is turned off, preventing water flow to your shower.
      • Using your flat head screwdriver, remove the screw from the middle of the handle.
    2. Shower Handle O-ring  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your groove joint pliers to loosen and remove the escutcheon plate.
    3. Shower Handle O-ring  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your groove joint pliers, loosen and remove the cartridge stem.
    4. Shower Handle O-ring  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly unscrew and remove the stem completely.
      • There may be some water leakage due to built up pressure.
    5. Shower Handle O-ring  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shower Handle O-ring  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
      • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
      • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
      • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
Cori Fitzpatrick
crwdns2935283:003/20/16crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-6, Lauer Spring 2016 crwdns2935289:0Michigan Tech, Team 1-6, Lauer Spring 2016crwdne2935289:0
MTU-LAUER-S16S1G6
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 99
crwdns2936753:030crwdne2936753:0 416
crwdns2959996:0crwdne2959996:0 27,870
