Shop-Vac MC150A Motor Replacement
  1. Shop-Vac MC150A Motor Replacement, Unlatch the power unit assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Motor Replacement, Remove the top cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shop-Vac MC150A Motor Replacement, Remove the top cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Motor Replacement, Disconnect the switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shop-Vac MC150A Motor Replacement, Disconnect the switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shop-Vac MC150A Motor Replacement, Disconnect the switch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shop-Vac MC150A Motor Replacement, Unscrew the motor bracket: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
  7. Shop-Vac MC150A Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shop-Vac MC150A Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, be sure to reattach the green ground wire clip to the bracket.
  8. Shop-Vac MC150A Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the clip from the green wire and transfer it to the replacement motor.
  9. Shop-Vac MC150A Motor Replacement, Motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shop-Vac MC150A Motor Replacement, Motor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor bracket.
  10. Shop-Vac MC150A Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the part over to the other side.
    • Use the socket wrench remove the bolt securing the aluminum plate.
  11. Shop-Vac MC150A Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two Phillips head screws holding the cover to the motor.
    • After removing the cover to the motor, you can replace the motor.
Ngunlian
crwdns2935283:002/08/16crwdne2935283:0
744 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 1-2, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S1G2
crwdns2935297:013crwdne2935297:0
Where do I buy a new motor?????
Gerald Mikel - crwdns2934203:0crwdne2934203:0
Yeah that's what we all would like to know, removing is the easy part
Junkyard_Boxer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 248
crwdns2942667:0crwdne2942667:0 29,118
