Shenzhou k680e Silicone Grease Replacement
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shenzhou k680e Silicone Grease Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze new thermal paste onto the chips.
Yizhen Qu
crwdns2935283:009/20/20crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
York University, Team S2-G22, Melo-Thaiss Fall 2020 crwdns2935289:0York University, Team S2-G22, Melo-Thaiss Fall 2020crwdne2935289:0
YORK-MELO-THAISS-F20S2G22
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 1,486
