Sharper Image iPulse SI325 LED Lights Replacement
  1. Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
  4. Sharper Image iPulse SI325 LED Lights Replacement, Speakers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement, Speakers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
    • Wiggling the connector back and forth as you pull will make removal easier.
  5. Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
  6. Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights.
    • Slowly lift the circuit board out of the front cover and place the cover out of the way.
  7. Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image iPulse SI325 LED Lights Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the solder connecting the LED light that needs replacement.
Melissa Pasa
crwdns2935283:010/13/13crwdne2935283:0
701 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-33, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 11-33, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S11G33
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 662
