Sharper Image SVC430 Tripod Nut Replacement
  1. Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Tripod Nut Replacement, Tripod Nut: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two screws that attach the tripod nut to the device.
  12. Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharper Image SVC430 Tripod Nut Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws located on the back of the half that the tripod nut is located.
    • Once the screws are removed, the tripod nut can easily be removed.
Kathryn Mattingly
crwdns2935283:001/29/16crwdne2935283:0
698 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-6, Matravers Spring 2016 crwdns2935289:0University of Kentucky Louisville, Team 1-6, Matravers Spring 2016crwdne2935289:0
LOUISVILLE-MATRAVERS-S16S1G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 290
