Sharp Microwave Door Switch Replacement
  1. Sharp Microwave Door Switch Replacement, Door Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp Microwave Door Switch Replacement, Door Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Sharp microwave running with door open
    • Problem with the hardware interlock switches triggered by the door latch
    • Sharp model R-248BS
    • Unplug the microwave before you begin disassembly.
  2. Sharp Microwave Door Switch Replacement, Remove screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Remove screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Remove screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Side screw
    • ...and 4 screws in the back
    • Star screws need T15X4 or equivalent. A flathead can be used in a pinch.
    • Remove the screws
  3. Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Remove the screws (5 in number)): crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the case, should slide out with a little bit of effort.due to notches in the frame on the front top left ( when looking from the back).
  4. Sharp Microwave Door Switch Replacement, Microwave with the cover open: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Microwave with the cover open: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Microwave with the cover open: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now we will identify the switches
    • The lower two switches
    • ... and the upper switch
    • Upper switch faulty
    How do you know if the switch is faulty if we don’t know the original configuration of what it was supposed to be to start with?
    G B - crwdns2934203:0crwdne2934203:0
    Use a multimeter. Or the easiest way is to listen to the click sound from your switch, but it certainly won't be as accurate as using a multimeter.
    Edwin Jones -
    If the popup plastic tab ( the actuator for the switch) is loose or has a soft click, it is bad.
    Else you can use a multimeter to see if the switch resistance changes when the popup button is pressed (continuity change check)
    Sanjay Don - crwdns2934203:0crwdne2934203:0
    DO NOT touch the capacitor! 2100 Volts can kill! BE CAREFUL! The capacitor can be charged even when the microwave is unplugged.
    Joseph Watson - crwdns2934203:0crwdne2934203:0
    Which switch is normally open and normally closed of the three? I have this model, and may have swapped them and now am not sure which goes where!
    Daniel Fox - crwdns2934203:0crwdne2934203:0
  5. Sharp Microwave Door Switch Replacement, Replacement of the switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Replacement of the switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp Microwave Door Switch Replacement, Replacement of the switch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Top switch appears loose
    • Replace and reinstall
    • Angled reinsertion to line up hole with plastic support
Sanjay Don
crwdns2935283:012/24/17crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
Some Sharp Microwaves use different Torx screws. The T15 didn't fit the screws on my model, it appears to be the security version of the T15. I suggest getting a set such as the Mako instead.
DBDigital - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 5,191
