Sharp LC-42D62U T-Con Board Replacement
  1. Sharp LC-42D62U  T-Con Board Replacement, Remove the SD card cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To replace the T-Con board it is not necessary to remove the base.
    • Lay the the TV flat on a padded surface.
  2. Sharp LC-42D62U  T-Con Board Replacement, Detach the rear cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 17 screws.
  3. Sharp LC-42D62U  T-Con Board Replacement, Remove the stand fixing angle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble all the parts easily, mark with a permanent marker the location of the screws you are removing.
    • 4 screws hold the nd fixing angle.
  4. Sharp LC-42D62U  T-Con Board Replacement, Remove left and right center angles: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2 screws hold each center angles.
  5. Sharp LC-42D62U  T-Con Board Replacement, Remove the main shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 9 screws.
  6. Sharp LC-42D62U  T-Con Board Replacement, Disconnect connectors: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wisdom here.
  7. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray chassis: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 7 screws.
  8. Sharp LC-42D62U  T-Con Board Replacement, Remove the tray fixing angles and the lug angle top: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7 screws holding the lug angle top.
    • Then remove only the bottom screws from the tray fixing angles, leaving the top screws attached to the lug angle top.
  9. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board shield: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 5 screws.
  10. Sharp LC-42D62U  T-Con Board Replacement, Remove the last screw and disconnect the 4 ribbon cables: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To disconnect the ribbon cables, lift the brown tab on the connector.
    • Make sure the ribbons are positioned correctly in the connector when reassembling the new board.
  11. Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp LC-42D62U  T-Con Board Replacement, Remove the T-Con board: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two pads glued under the board (see yellow marks in the picture): use a heat gun to soften them and then gently pry them to detach the board from the frame.
    • There are also 4 tabs holding the board: gently pull the board to release it, after the pads are disconnected.
    • Reposition the pads on the chassis before installing the new board.
Emme
crwdns2935283:006/15/17crwdne2935283:0
871 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 1,306
