Sharp EL-520X Loose Circuit Board Wire Fix
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp EL-520X Loose Circuit Board Wire Fix: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
Mohamad Mohamad
crwdns2935283:001/18/21crwdne2935283:0
457 crwdns2915208:0crwdne2915208:0
York University, Team M-6, Allen Summer 2023 crwdns2935289:0York University, Team M-6, Allen Summer 2023crwdne2935289:0
YORK-ALLEN-SU23SMG6
crwdns2942667:0crwdne2942667:0 569
