If the volume is not adjusting when you try to change it you may need to replace the volume rocker. This may be because it has become separated or the clips have broken off.
Begin by using the nylon spudger to pry off the back case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to pull the volume rocker from the clips.
