Sharp Aquos Crystal Battery Replacement
  1. Sharp Aquos Crystal Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp Aquos Crystal Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp Aquos Crystal Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    Sense4liteなんですけど全く取れないです
    kpt - crwdns2934203:0crwdne2934203:0
    Helo my back camera problem please Oder my camera
    Umar Umar - crwdns2934203:0crwdne2934203:0
  2. Sharp Aquos Crystal Battery Replacement, USB Port: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp Aquos Crystal Battery Replacement, USB Port: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp Aquos Crystal Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp Aquos Crystal Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sharp Aquos Crystal Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sharp Aquos Crystal Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    Hello
    I would like to buy a Sharp c10 Aquos Crystal USB Port
    Can you help me with that ???
    ابو مصطفى - crwdns2934203:0crwdne2934203:0
    I need this part (aquos r2) I'm from Pakistan
    Faisal Abbas - crwdns2934203:0crwdne2934203:0
  7. Sharp Aquos Crystal Battery Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp Aquos Crystal Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Battery Replacement, Battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the tape holding the battery down.
  13. Sharp Aquos Crystal Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sharp Aquos Crystal Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery out with your hands.
crwdns2935229:09crwdne2935229:0
Felicia Imbriano
crwdns2935283:003/08/16crwdne2935283:0
1 239 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-4, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 7-4, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S7G4
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - crwdns2934203:0crwdne2934203:0
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - crwdns2934203:0crwdne2934203:0
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 17,609
