If your phone is not turning on or charging, you may need a new battery.
This guide will show you how to open your device and remove the inside motherboard to replace your battery.
Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
Disconnect the wire by lifting it up with a plastic opening tool.
To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
Peel off the black pieces of tape.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
Lift the motherboard out with your hands.
Peel off the tape holding the battery down.
Lift the battery out with your hands.
crwdns2935229:09crwdne2935229:0
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
