The battery plays a key role in your vacuum function. Over time, the lithium-ion battery will lose its ability to fully charge and may need to be replaced. Follow this simple guide to safely remove and replace the battery of your Shark Wandvac Power Pet WV410. You do not need any additional tools to complete this process.
Before you begin, make sure your Shark Wandvac Power Pet WV410 is powered off.
Squeeze the tabs at the base of the handle to release the battery from the vacuum.
Pull the battery straight out from the bottom of the device.
