If your Shark Vertex Pro IZ682H vacuum isn’t effectively picking up debris or if the brush roller has stopped spinning entirely, this guide will show you how to replace the brush roller motor belt on the power nozzle.
The brush roller belt drives the roller, helping the vacuum agitate and lift debris from floors. A worn or broken belt can lead to poor suction and decreased cleaning performance. Before beginning this repair, visually inspect the brush roller for obstructions, such as hair or threads, which can sometimes cause issues similar to a worn belt. Make sure the vacuum is powered off and disconnected from any power source.
Follow each step closely to ensure proper belt replacement and restore your vacuum’s performance.
Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab in the direction of the arrow.
The brush roller should now pop out.
Hey there, where can I find the replacement rollers? I have been looking around and I do not see any that name the product exactly or in listed in compatible. Are they standard size or something like that?
