Shark Vertex Pro IZ682H Brush Roller Belt Replacement
  1. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab in the direction of the arrow.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
  2. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller Belt: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the three plastic locks to the unlocked position, then remove the crevice tool.
    • Use T9 and T15 screwdrivers to remove the seven screws.
  3. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Vertex Pro IZ682H Brush Roller Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to pry along the edges of the casing, then remove the thin plastic coverings on both sides.
    • Expect to hear snapping noises.
    • Pull the plastic coverings off the powerhead.
  4. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws using a T15 Torx security screwdriver.
    • Remove the plastic headcover.
  5. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven screws using the T10 and T15 Torx security screwdriver.
    • Lift the covering and motor assembly enough to see the belt.
  6. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the belt from the power nozzle.
    • When reinstalling, be sure the belt is tightly secured around the gear grooves.
Tyree Brooks
crwdns2935283:010/26/22crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-2, Botvin Fall 2022 crwdns2935289:0UMass Dartmouth, Team 3-2, Botvin Fall 2022crwdne2935289:0
UMASSD-BOTVIN-F22S3G2
Thanks for the instruction. It helped, however, I cannot find the brush anywhere that goes to this vacuum (the one that attaches to the belt)
Eric - crwdns2934203:0crwdne2934203:0
Hey I am looking for the brush. Did you manage to find it or find an alternative?
John Melo -
Yeah, it seems that shark will only sell us the entire floor nozzle, not just the power fins roller. Oh, and when they sell you that entire piece for $100 they don't include the soft brush roller! The nerve of this company. I just want to be able to remove the power fin roller and wash the darn thing. Or heaven forbid I want to clean the dirt on the inside of the top cover. It's just ridiculous. I can't seem to find instructions anywhere on the web for how to remove the power fin roller.
radtech - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 139
crwdns2942667:0crwdne2942667:0 8,831
