This guide will provide instruction for replacing the motor of a Shark UltraCyclone CH951. The motor is the mechanical part of the vacuum that provides the suction. If the vacuum does not turn on or have suction, the motor may need to be replaced. The motor and the battery are attached in this model, so they will need to be taken out together.
Press the dust cup release button and gently pull the dust cup away from the body of the vacuum.
Use a TR9 Torx screwdriver to remove the two 8.7 mm screws previously behind the dust cup.
Remove the two 12.2 mm screws underneath the dust cup button using a TR9 Torx screwdriver.
Remove the 13.9 mm screw beneath the charging port using a TR9 Torx screwdriver.
Use the TR9 Torx screwdriver to remove two 11.6 mm screws that hold the exterior motor in place.
Run an iFixit Opening Tool under the casing along the vacuum body until the shell is removed starting around the attachment port, and sliding down towards the charging port.
Press down on the connection point of the white wire and disconnect it.
Disconnect the red wire by squeezing each side and gently pulling the two sides apart.
Gently pull on the exterior motor.
Remove the exterior motor, attached to the interior motor and battery.
Squeeze the translucent rubber cover on the two wires and gently pull apart to disconnect both of them.
