Shark Stick Vacuum lock Pin Replacement
  1. Shark Stick Vacuum lock Pin Replacement, lock Pin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Also note ifixit forced me to crop the image so some of it is cut off??
    • NOTE: There is a screw under one of the front rollers!
    • use T20 security bit to remove screws.
  2. Shark Stick Vacuum lock Pin Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • use a T10 security bit
    • carfuly pry off top plastic plate. I cracked it, so be careful.
  3. Shark Stick Vacuum lock Pin Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • note: I made a typo in the image. should say "spring"
    • reference image. in next step we will put the pin back in
  4. Shark Stick Vacuum lock Pin Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove plastic cap on wheel. You a drill bit to cut a large hole on the end. we will use this hole to insert the pin.
  5. Shark Stick Vacuum lock Pin Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • put the white plastic piece into position and insert the pin through the hole we drilled in the wheel. ensure the spine end goes in first and the pin is full seated.
    • put spring onto the nub. and reassemble vacuum.
Zen
crwdns2935283:007/18/24crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 160
crwdns2942667:0crwdne2942667:0 1,513
