Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement, Roller Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wiggle the brush roller upwards from the left and right side slots.
Daniel Ceja
crwdns2935283:001/24/19crwdne2935283:0
289 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G3, White Winter 2019 crwdns2935289:0Cal Poly, Team S19-G3, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S19G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,098
