Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Joshua Morrison
crwdns2935283:001/24/19crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G3, White Winter 2019 crwdns2935289:0Cal Poly, Team S19-G3, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S19G3
What is the motor PN and where can I get one?
Dennis Meece - crwdns2934203:0crwdne2934203:0
Somewhere in the process I ended up with a 5" coil spring with a plastic stopper on one end about 1/2" in diameter. Can you tell me where it belongs?
Edward Van Grol - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,774
