If the brush does not spin and the motor still works, then the brush belt may be worn down or damaged.
This guide will aid in replacing that belt.
Push the lift away button and pull the handle up to separate the body from the wand section.
Push lift away button on the wand then lift up on the top section to separate.
Tilt the wand shaft backwards for convenient.
Lay the head nozzle piece upside down.
Rotate the three gray taps to the unlock position.
With your fingers, pry and pull the brush cage open.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
Lift up the top cover now that all of the screws have been removed.
Pry tab out with a flat head screwdriver or any wedge-like tool.
Gently press in on brush to detach.
Pull brush down and out.
where did you get new belts? I bought a set from Amazon for a Shark NV752 and the belts are a bit to large.
