Shark Rotator Lift-Away Speed Brushroll Replacement
  1. Shark Rotator Lift-Away Speed Brushroll Replacement, Brushroll: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Brushroll Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Lift-Away Speed Brushroll Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Brushroll Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Lift-Away Speed Brushroll Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
Weston Mongomery
crwdns2935283:010/02/17crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G7, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S15-G7, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S15G7
crwdns2942667:0crwdne2942667:0 1,973
