Shark Rotator Lift-Away Speed Belt Replacement
  1. Shark Rotator Lift-Away Speed Belt Replacement, Brushroll: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the vacuum is turned off and unplugged before proceeding.
    • Locate the release button at the top of the vacuum pod next to the handle.
    • Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
    • Removing the pod is optional, but it may be easier to locate blockages or access the motor and belt if you do so.
  2. Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
  3. Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the brushroll out by using the pull-tab on the left side.
    • You can test the brushroll once it has been inserted by plugging the vacuum in and running the vacuum in carpet mode. The brushroll indicator light should be a solid green color.
  4. Shark Rotator Lift-Away Speed Belt Replacement, Brushroll Motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 5mm Torx #9 screws on the front side.
  5. Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 7.5mm Torx #20 screws on the bottom face of the nozzle.
    • A screwdriver extension may be necessary to reach the screw closest to the center of the nozzle.
  6. Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top panel by lifting the top piece off of the bottom.
    • There will be loud clicking noises.
  7. Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you are trying to remove the belt, you may skip to the next step.
    • Remove the 7.5mm Torx #20 screw in front of the motor.
    • The motor is the gray block on the right side of the floor nozzle (when the nozzle faces towards you).
  8. Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rotator Lift-Away Speed Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the panel to reveal the motor screw.
    • Remove the 7.5mm Torx #20 motor screw.
    • Remove the motor.
  9. Shark Rotator Lift-Away Speed Belt Replacement, Brushroll Belt: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black belt located on the right face of the vacuum nozzle.
    How do you reattach the belt …… that’s where I’m struggling
    Lisa Munn - crwdns2934203:0crwdne2934203:0
Samantha Woo
crwdns2935283:010/02/17crwdne2935283:0
330 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G7, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S15-G7, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S15G7
where can I purchase the wheel shown in the photo above??
Kay Sherbeck - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 134
crwdns2942667:0crwdne2942667:0 11,095
