This guide is intended to show how to access, remove, and replace the belt on a Shark Rocket Stick Vacuum with Self-Cleaning Brushroll. This replacement may be necessary if the brush roller is turning slowly or not at all.
Flip the vacuum on its right side.
Turn the T10 Security Bit screwdriver counterclockwise to remove the 15mm screw.
Turn the vacuum face down.
Use a spudger to pry the side of the vacuum open.
Use a spudger to pry the old belt away from the two gears.
Repeat on the other side of the vacuum.
What is the belt part number looking but can not fine.
Help would be greatly appreciated thank you
