Shark Rocket Professional Hose Replacement
    1. Shark Rocket Professional Hose Replacement, Main Hose: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rocket Professional Hose Replacement, Main Hose: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rocket Professional Hose Replacement, Main Hose: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Look at the Shark Rocket Professional's Extension Rod.
      • Identify where the hose connects to the main body of the vacuum.
      • Press the tabs on the sides of the connector to remove the hose.
      • You can use a long, thin object to unclog the hose.
      • If this fixes your problem, then you are finished with this guide.
    2. Shark Rocket Professional Hose Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rocket Professional Hose Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
      • Press the button and remove the handle.
    3. Shark Rocket Professional Hose Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Rocket Professional Hose Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Look at the vacuum handle.
      • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
    4. Shark Rocket Professional Hose Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rocket Professional Hose Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rocket Professional Hose Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to pry open the handle.
      • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
      • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
    5. Shark Rocket Professional Hose Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark Rocket Professional Hose Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark Rocket Professional Hose Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The orange plastic piece may have naturally fallen out at this point.
      • Look a your handle.
      • Using your hands, pull the tube from the nozzle of the handle.
      • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
      • Cut this connection with wire clippers to remove and replace your tube.
Brad Iglesia
crwdns2935283:001/24/18crwdne2935283:0
316 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G6, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S18-G6, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S18G6
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do you replace the hose in the beater head
daveve2 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you for this, this guide helped a ton.
Bradlee Johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How long does it take to answer acquestion?
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 6,961
