A broken Brushroll Cap can cause your Brushroll to not able to rotate and pick up dirt properly. The Brushroll Cap comes off easily with the press of your thumbs. This guide will demonstrate how to replace the Brushroll Cap if it has become damaged.
Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
Lift the brushroll cover upward.
Lift the brushroll out by pulling the tab labeled "pull".
Remove the cap by pushing the "pull" tab.
