Use this guide to replace the motorized floor nozzle cover on a Shark Rocket HV322 if the motorized floor nozzle cover is damaged or needs to be removed to access components underneath it.
The motorized floor nozzle cover protects key components of the motorized floor nozzle like the brushroll motor and circuit board.
Be sure to turn off and unplug the vacuum before beginning.
Push down on the black wand release lever to remove the motorized floor nozzle.
Rotate the three locks that secure the brushroll cover with a spudger.
Remove the brushroll cover.
Remove the ten 9.4 mm Torx T8 screws on the bottom side of the motorized floor nozzle.
