Use this guide to replace your vacuum belt. A vacuum belt may need to be replaced due to wear and tear, damage, or loss of tension.
The purpose of a vacuum belt is to transfer power from the motor to the brush roll. This allows the brush roll to spin and agitate the carpet or floor, loosening dirt and debris so that the vacuum can effectively suction it up.
Make sure the vacuum is not connected to power before proceeding.
Use any object with an edge to twist the three locks counterclockwise to the "unlocked" position.
Use a Torx TR6 screwdriver to remove all ten 10 mm screws.
Remove the two small power nozzle wheels.
Use a Torx TR6 screwdriver to remove the 10mm center screw.
Use a Torx TR6 screwdriver to remove the two 10 mm screws that were hidden by the power nozzle wheels.
Lift the clear plastic brush roller housing up and off of the unit.
Use a Torx TR6 screwdriver to remove the two 10 mm screws that secure the belt.
Remove the belt.
