Shark NV352 Roller Brush Replacement
  1. Shark NV352 Roller Brush Replacement, Roller Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Roller Brush Replacement, Roller Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
    Removing the dust canister is not necessary.
    Taudris - crwdns2934203:0crwdne2934203:0
  2. Shark NV352 Roller Brush Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
    Instead of laying down the whole vacuum, remove the cord from the hooks, then, using the red button/lever on the side, detach the vacuum from the base. https://youtu.be/gQmme4xespU?t=69
  3. Shark NV352 Roller Brush Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Roller Brush Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
    It needs to be noted that this step will VOID the warranty!
    Tom Barnes - crwdns2934203:0crwdne2934203:0
    You can also use a small slot screwdriver to push directly on the metal rods that hold the wheels.
  4. Shark NV352 Roller Brush Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Roller Brush Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
    Leave the orange screws in. Removing the wheels is not necessary and does not make the repair easier.
    the whole floor unit can be removed which makes the job A LOT EASIER.
    john peters - crwdns2934203:0crwdne2934203:0
    Mine has stars instead of phillips head #2 screws! : (
    Rebecca Sellers - crwdns2934203:0crwdne2934203:0
  5. Shark NV352 Roller Brush Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Roller Brush Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
    Any advice on putting the wheels back on the vacuum? I cannot get the metal axle pins back into the socket all the way, and I’m hesitant to just bang them in.
    Scott Stepp - crwdns2934203:0crwdne2934203:0
    Im not even sure taking out the wheels is necessary. They dont appear to be attached to the purple plate.
    gatchi - crwdns2934203:0crwdne2934203:0
  6. Shark NV352 Roller Brush Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Roller Brush Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the roller brush by lifting it out of its tray.
    Me interesa adquirir el cepillo de esta aspiradora y conocer la ubicación del centro de servicio técnico en San Luis Potosí. Slp. Mex
    psclolita - crwdns2934203:0crwdne2934203:0
    Saber centro de servicio tec. En slp
    Be careful not to pinch any wires as you put the cover back on .
crwdns2935229:09crwdne2935229:0
Amy Moran
crwdns2935283:009/22/17crwdne2935283:0
603 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G5, Forte Fall 2017 crwdns2935289:0Cal Poly, Team S18-G5, Forte Fall 2017crwdne2935289:0
CPSU-FORTE-F17S18G5
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
elaina heinz - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 5,508
