Shark NV352 Motherboard Replacement
  1. Shark NV352 Motherboard Replacement, Roller Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Motherboard Replacement, Roller Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark NV352 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the roller brush by lifting it out of its tray.
  9. Shark NV352 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The capacitors on the motherboard may still hold a residual charge, so avoid touching them because there is a risk of getting shocked.
    • Remove the motherboard carefully so you don't cause damage by pulling the wires connected to it.
    • Lift the motherboard out of the plastic tray to remove it.
  10. Shark NV352 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wires connecting the motherboard to the vacuum by unscrewing the twist-on wire connectors.
    • Desolder the wires connecting the motherboard to the motor. Get tips on how to desolder by checking out How to Solder and Desolder.
Wesley T Benica
crwdns2935283:009/22/17crwdne2935283:0
378 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G5, Forte Fall 2017 crwdns2935289:0Cal Poly, Team S18-G5, Forte Fall 2017crwdne2935289:0
CPSU-FORTE-F17S18G5
crwdns2947412:05crwdne2947412:0
Thanks Thomas! Your support is greatly appreciated!
Vincent Leuzze -
Any knowledge on how to fix or replace the handle lick button. Mine won't lock and so the whole vacuum doesn't work
Jana Butler - crwdns2934203:0crwdne2934203:0
I have a 350 will the 352 powerhead motherboard work as a replacement as I can’t find a 305 one
chaseraymond - crwdns2934203:0crwdne2934203:0
I have a 350 vacume but need a replacement powerhead circuit board would the 352 work? It looks the same and it’s the same unit?
crwdns2942667:0crwdne2942667:0 1,542
