If the handle for your Steam Pocket Mop gets loose and falls off, or if you would like to remove the handle for easy storage, use this guide to walk you through the process. You will need a Phillips #2 screwdriver for this replacement.
Turn off the Steam Pocket Mop and unplug it from the wall.
Place the Steam Pocket Mop face down on a flat surface.
Remove the screw located underneath the cord holder.
Turn the screwdriver counter-clockwise to loosen the screw from its slot.
To disassemble your device, follow these instructions in reverse order.
