Shark IQ AV993 Wheels Replacement
  1. Shark IQ AV993 Wheels Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Wheels Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Wheels Replacement, Bumper: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark IQ AV993 Wheels Replacement, Bumper: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Wheels Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Wheels Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
  6. Shark IQ AV993 Wheels Replacement, Wheels: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark IQ AV993 Wheels Replacement, Wheels: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip over the vacuum so that the bottom is facing upwards.
    • Remove the five 14 mm screws using a T20 Torx screwdriver.
  7. Shark IQ AV993 Wheels Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull upward on the wheel to remove the wheel housing.
    • Carefully remove this as there is a clip connecting to the wheel.
    • Press the tab on the clip and slide the wires out of the housing.
    • Repeat this step and the previous step for the other wheel assembly.
Marc Farah
crwdns2935283:010/26/22crwdne2935283:0
94 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-3, Botvin Fall 2022 crwdns2935289:0UMass Dartmouth, Team 3-3, Botvin Fall 2022crwdne2935289:0
UMASSD-BOTVIN-F22S3G3
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 467
