Shark IONFlex 2X Wheel Replacement
crwdns2942287:0crwdne2942287:0This replacement guide does not require tools. This guide will show the user how to remove the wheels from their device.
Pull the wheel away from the floor unit base with a strong pull.
Repeat steps for the other side.
Thanks for the information but you have neglected to say that the 2 screws that hold the 2 axles in place also need to be removed and that 2 different screw heads have been used.
Where do you get the wheel replacement?
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
Great, now to actually find replacement wheels :/
Any idea where I can purchase a replacement wheel?
There is a vacuum tube between the wheels, will removing the wheels get me access to the tube, there is a hole in the tubing,thus crud escapes into the air. If there's a way to repair this i would love to know how. Great vacuum, crap for construction quality and the tools required to remove the base plate are not standard household tools. Any ideas would be kindly appreciated. Thank you
