NOTE: This part of the replacement guide does not require tools.
This part of the replacement guide focuses on the replacement of the soft brush roll, which is the brush roll which is more prone to wearing out. The soft brush roll was designed to be easily replaced by the user.
Press and slide the access brush roll buttons towards the "Access Brush Roll" printing on casing.
Lift plastic casing upward and off of the top of the floor unit. Place off to the side.
Pull the red Pull tab that is located on the right side of the soft brush roll away from the front of the vacuum and place the soft brush roll to the side.
I’m trying to fix the plastic gear that the roller fits onto. It’s broken and I think it needs to be disassembled more and need replacement parts. Model # IF200W. Any advice??
