Is your Shark ION Robot S87 battery draining quickly or not charging? This is because batteries have a life span which decreases with every charge. If that is the case, you may need to replace the battery.
Flip the device so its underside is facing up.
Use the Phillips #1 screwdriver to remove the two 14mm screws.
Once you have removed the screws, open the battery lid.
Hold both sides of the battery using the plastic tabs.
Use the plastic tabs to pull the battery out.
Disconnect the battery from the device by pulling it out of the circuit.
