Shark ION Robot R75 Battery Replacement
  1. Shark ION Robot R75 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
    Here, you have misused the reminder bullet. The note bullet would be better in this case; I would also say how to turn it off, rather than just to do it. Avoid locate steps, and instead, move straight to the information about what to do. Use markup on the images to indicate where the component is. Be careful about using “remove” without other information about how to remove it, especially if there are multiple ways to remove something.
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  2. Shark ION Robot R75 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Shark ION Robot R75 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
    Make sure to review how to appropriately use special bullets. Make sure to check throughout to remove “locate” steps, and instead, just go straight to the action.
  3. Shark ION Robot R75 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark ION Robot R75 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
    Here, you’re using tweezers, but you don’t indicate that in the guide steps. Instead of including the information in the special bullet, I would just integrate the tool into the actual procedure. Do you have pictures of you pushing the tab? Can they yank the wire, or do they need to pull gently? I would add a flipbook style action shot to make the procedure clearer in the pictures.
Andrew Lowy
crwdns2935283:001/25/20crwdne2935283:0
599 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G6, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G6, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S3G6
After charging for several hours, my robotic shark stops after 10 minutes. I can push the start button and it will run for another 10 minutes. This has been repeated several times with out it docking itself. What are your thoughts on this?
Marsha Moon - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,895
