Emptying the dust bin on your Shark ION RV754 helps ensure it will function properly. When the bin gets full of dirt, dust, and hair, the vacuum can lose power and won’t work as well. To keep it running strong and your floors clean, it’s important to empty the bin often.
Before you begin, make sure your vacuum is powered off and disconnected from the charging dock or charger.
Press the dust bin removal latch and slide out the dust bin.
To open the dust bin, hold the tray with two fingers at the indicated holes and pull the opposite side with your other hand.
Empty the debris and dust into the trash.
