Shark Flex DuoClean Suction Motor Replacement
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Suction Motor Replacement, Dust Cup: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
Christian Fuller
crwdns2935283:010/08/18crwdne2935283:0
423 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G5
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,813
