Shark Flex DuoClean Motor Replacement
  1. Shark Flex DuoClean Motor Replacement, Garage Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Motor Replacement, Garage Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motor Replacement, Side Component: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Motor Replacement, Side Component: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    I know it is absolutely essential to have a security bit on here to change the belt as you wouldn't want anyone accidently changing it.
    Deb Winters - crwdns2934203:0crwdne2934203:0
  4. Shark Flex DuoClean Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motor Replacement, Top Component: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
    needed to remove 8 screws to get top off
    Martin Bell - crwdns2934203:0crwdne2934203:0
  7. Shark Flex DuoClean Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motor Replacement, Brush Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean Motor Replacement, Brush Motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the vacuum so you are looking down at the open garage of the vacuum.
    • Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
    There are two screws holing the motor in place. You need to remove the belt first, and then the 2 pozidrive screws before you can
    remove the motor as per your instructions.
    pete Book - crwdns2934203:0crwdne2934203:0
  9. Shark Flex DuoClean Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With both thumbs, push the gear on the right side of the motor into the vacuum. The motor should pop out.
    • Slowly pull the motor out of the vacuum base and reveal the electrical cords.
  10. Shark Flex DuoClean Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To fully remove the motor, cut the wires.
    • For reassembly, use the soldering guide in the Introduction.
Samantha Mickelson
crwdns2935283:010/08/18crwdne2935283:0
496 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G5
crwdns2947412:07crwdne2947412:0
Can this motor we test it before taking it out
craigfranz - crwdns2934203:0crwdne2934203:0
Can this motor be tested before taking it out?
How do I know if the motor is burned out
Danny Manuele -
Will you be able to take out the brush roll in front of the motor?
CAM BAP - crwdns2934203:0crwdne2934203:0
Great fix. I wonder if you know how to find a replacement motor? My Dyson motor died and I’m not sure where to start looking for a replacement part - Dyson don’t sell it.
TyN - crwdns2934203:0crwdne2934203:0
It must be for a different model slightly or a newer model because mine has Allen head security screws and not torques and my motor is screwed in not just popped in.
Dan Conklin - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 23,512
