Shark Flex DuoClean LED Headlight Replacement
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean LED Headlight Replacement, Garage Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean LED Headlight Replacement, Side Component: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side component with your hands.
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
  8. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  9. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
  10. Shark Flex DuoClean LED Headlight Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
Samantha Mickelson
crwdns2935283:010/08/18crwdne2935283:0
496 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G5
crwdns2942667:0crwdne2942667:0 1,510
